I got two requests for stuff associated to the emanage ultimate so I decided I would post it up.
There are three files attached.
EU install help.pdf is a pdf I made illustrating how I installed the EU and the little tricks I used to get it to work the way I wanted. ie. adding a knock sensor, outputing to a led if the knock went too hig. etc.
kyle diagram.pdf is a pdf I made for an old schooler showing him hopw I set up a quick disconnect. I put a male female plug in the middle of all connections going to the EMU so if i needed to disconnect it and go back to the "stock" wiring/ecu connections, I could.
The last file Curent +6 above 11.6psi 12_10_09.pdf IT IS NOT A PDF. I had to upload it this way because the uploader would not take it as an EM2 extension.
Take off the extension (pdf) and put on EM2. It is an actual tune for my car before I went over to Osiris. It should be tuned up to 15-20 psi. If you are running a 02-03 MAF clear out the "airflow adjustment map". I tuned based on PSI which worked best for me. You need a boost sensor for this to work so if you want to tune by another method you are SOL.
Injector latency is based on modded stockers. The O2 sensors were not attached. But I think the baseline of the injectors are close enough that the tune would not drift if they were.
IF YOU BREAK YOUR CAR USING THIS MAP I AM NOT RESPONSIBLE.
Here are the car's specs associated with the MAP
Modded Stockers (static pressure 60psi)
T3/t4 .60/.63
04+MAF
8.5:1 Compression pistons
3"exhaust
T3/t4 .60/.63
04+MAF
3"exhaust
