Hey yall. I used the forum search as best as I could to find some info on this but came up short. Hope someone has some insight.
I have a boosted a built QR25DE 02 Spec V that has been sitting for 5+ years so the fuel in the tank is bad. Should have put Stabil in earlier; lesson learned.
I wanna know if anyone has tried the method of using the fuel pump relay to pump the gas out of the tank. Similar to this video. I replaced the fuel pump myself (damn thing was hard to fit into the fuel pump assembly) so I know that the assembly/pump are under the rear seats. What line would I need to remove under the hood to pump the gas out?
The car is headed to a tuning shop soon but I want to remove the fuel and put some fresh fuel in there before it gets to the shop. I recently tried to start the car for some silly reason so I'm slightly concerned about the bad gas ruining the Walbro 255 pump I have in there while the car waits 2-3 weeks for the shop to start on it. It would also be nice to be able to start the car even briefly so I can drive it onto a car dolly/get it out of the garage for the tow person.
Any advice? I tried siphoning but most cars from the mid 90s and later won't really let you run a tube all the way down into the fuel tank
