1 - 5 of 5 Posts
Engine parts for 03-06 1.8L < 5,000 Miles - Cylinder Head, Manifolds, Sensors, etc...
I removed a QG18DE engine from a 2003 Sentra back in 2003 and saved all the parts until today. The engine had less than 5,000 miles so all the parts are basically like Brand New. All the parts fit 2003-2006, except the timing chain, front cover, and crank pulley will fit 2000-2006.
Complete Head with Valve Cover $395.00
Exhaust Manifold/Convertor/Sensor $295.00
Fuel injectors with rail $145.00
Throttle Body Assembly $95.00
Intake Manifold/Collector $95.00
(3) Ignition Coils $95.00
Intake Timing Gear $145.00
Timing Chain Parts/Cover/Pump $95.00
Crank Pulley with bolt $75.00
Flex Plate $35.00
Purge Valve $35.00
Knock Sensor $34.00
Discussion Starter #2
The exhaust manifold/convertor, intake/collector, as well as the timing chain/cover have been sold. If you want to see more pictures...the other parts are listed on eBay under seller: z2zee
The cylinder head and valve cover are now being sold separately. The cylinder head is $345 and the valve cover $65. The throttle body, flex plate, as well as the purge valve have been sold. If you want to see more pictures...the other parts are listed on eBay under seller: z2zee
The fuel injectors and intake timing gear have been sold. The 4 items that we have left are the cylinder head, valve cover, ignition coils, and crank pulley. If you want to see more pictures...they are listed on eBay under seller: z2zee
The cylinder head and valve cover have been sold. The 2 items that we have left are the ignition coils which are now for $69, and the crank pulley $59. If you want to see more pictures...they are listed on eBay under seller: z2zee
1 - 5 of 5 Posts
