Hey guys, it's been ages since I've been on here or posted, life got in the way and I had to postpone my project.
Now I'm back, and the engine and trans are sitting on a pallet awaiting my next move.
I had my eyes on an engine at a local parts yard, 157k or so and running. Of course it sold 2 days before I was gonna go get it.
So now I'm either waiting until I can find another to buy, or to rebuild my current one.
I come here for your opinions though, I would like to take the car on my yearly trip to Florida with my family in 5 months, meaning I need to replace the engine with another, or rebuild it much before then. My budget is a little tight but able to be stretched for necessary improvements or repairs. Currently I know it needs a 4 wheel brake job, maybe even calipers but I'm not fooling with that until its done. The spare tire compartment needs to be cut out and have a new one welded in, and some other odds and ends.
But the biggest fish to fry is the engine. So I come to ask, what do you guys recommend? Wait for another lucky chance at a used engine, or rebuild? I'm no stranger to engine overhauls or any work on a vehicle and can do it all.
What parts do you guys recommend?
Tips to make this a little less painful?
Improvements I should do while it's out?
Some history of the motor
The compression test came back low, its been so long I can't recall the specifics, I remember the two cylinders in the middle had considerably less then the rest.
The leakdown test showed terrible results, (once again its been so long I can't remember the specifics)
The butterfly screws are intact.
Whenever it would run, it would smoke like a train.
Evidence as I remember would almost point towards a head gasket / warped head, but considering the cat has been gutted, I'm personally unsure what to think. I almost wonder if it ate the pre cat and the last guy gutted it as a hopeful attempt, or maybe he gutted it knowing what happens to these things, and overheated the engine due to unrelated things, thus blowing the head gasket and warping the head.
Like usual, I'm just kind of at a loss of direction here.
I know even if I tore it down and found a headgasket or warped head issue, I would completely overhaul the engine just to be sure it would be able to be trusted. It's already out so I'd much rather do it now.
