Everything must go sale.
Tial 38mm wastegate. New diaphragm, New aluminum crush washers. Slight grind on housing was there when I bought it. Did not effect functionality. I believe there are combined 14lb springs in it. I ran it with no issues. 150.00 shipped
JWT Lightened Flywheel. Would replace the Friction surface. 150.00 +Shipping (Pending sale to Jeremy)
Five-O 1000cc @ 43.5 PSI injectors Bosch EV-14 PN# 026U1000
Latency [email protected]
Resistance 12.5Ohms
20% drop /-1Volt
at 20 psi I had some head room left if I remember correctly. One of the injectors needs a Oring seat. I did howerver run it without. 200.00 shipped
For you guys that want to try an electric power steering pump.... The go to volvo pump with harness attachments. 100.00 + Shipping (Pending sale to Mirrortints)
Rear Calper Brackets for brembo upgrade. 40.00 +shipping
A piece of History. Protech Turbo Mani and Downpipe modded for 3" Vband. Needs some TLC, there is a crack between runner 3 and 4 but a good welder can fix it for cheap. 250.00 +shipping
T04E Compressor housing from a GT35R .50AR 3" inlet 2" outlet, T3 Turbine housing from a GT35R .63AR 3" V-band Exhaust Side 100.00 + Shipping for
both
Resistance 12.5Ohms
20% drop /-1Volt
both
