1 - 9 of 9 Posts
Discussion Starter #2
this will really help in our set up...the old T3T4 not the new water cooled 2J one. But this helps remove the hose from the heat where it will live a nice long life...hopefully
just use stainless braided lines. I ran my -8 for 10 years and 60k before i went to -10. It doesnt leak and is still very flexible.
you still have rubber inside the braid of metal. Secondly, the vibrations cause a rubbing which may lead to failure. Third, the extension frees up room to reach the bolt to the compressor housing.
Reactions: yogi b
yea thats the big one for me too.
when I put the new spring in the wastegate ...another leaky seeping oilly drip. Traced it to the top of the drain hose. Where it met the fitting was complete cooked....so I installed this beauty. Gives a nice 3 inch drop from the 900* hotside.
Reactions: yogi b
1 - 9 of 9 Posts
