1 - 4 of 4 Posts
Hello
I need a little information ,
i built a qr25de with a cummins turbo with 575 pink injector , my setup is pretty done
i hook up my aem fic
but the resistor seem to change from model to others,
is it right to put the 1k like they said in the manual
or i need another one .... thanks
I think the 1k resistor is what I did way back when. But you may need to guess and check it
Really not necessary to o2 tune closed loop anyways, with that size injector fuel trims should be perfectly fine with only making the fuel table adjustments. Unless of course you want to run a different afr in closed loop then yes the 1k 1/4w resistor works fine on our cars.
Nice , Thanks you for your answer , I Will put the 1k ans check it , I Will came back with my result :) , :)
1 - 4 of 4 Posts
