Ok, so my '06 1.8s didn't come with fog lights. Instead it came with these ugly ass caps(which I removed BTW).
I just recently got the OEM fog lamps but, there doesn't seem to be a place to screw them in. Is there some sort of bracket I need in order to install them?
there is a bracket. you gotta order them thru nissan. its like over 100 dollars for the pair. i had to order them too. it doesnt come with any bolts or anything. good ole' zip ties did the trick for me lol
Did you end up figuring it out? I've come across this issue, and was also wondering what you plugged the fog lights to? Was there a hidden harness?
THE COVERS HAD 2 SCREWS YOU WOULD REUSE FOR THE FOG BRACKET. THEN YOU NEED 4 10MM BOLTS FOR THE FOG LIGHTS TO MOUNT ON THE BRACKET.
