As you can see in the picture there's a part of the actual transmission casing that's broken off. Where the bolt screws into the transmission that attaches to the motor mount bracket there's a ton of thread missing and I'm afraid it's not gonna hold that motor mount well. When I bought the car it didn't even have those 2 motor mount screws so I went to the junkyard and got some off another car. I need something that's gonna work in the long run, so in my attempt to resolve this issue I've put loctite in the bolt in the bit of thread that's left on the top bolt hole and did the same for the bottom bolt hole. Also put lock washers on both. I put some of the strongest JB weld I could find on the exposed bolt hole after sanding around the area with some 80 grit and cleaning it off. I Left a jack stand under the transmission supporting it while all that stuff cures. I'll take a finished picture tomorrow. I replaced that motor mount too. If anyone has any idea on how I can maybe secure this a little better please I'm open to any ideas
