After this summer i will have the c1 cams, 2j intake manifold plenum, and the sniper nos kit (50 shot)
do you think i will need the 255plh and bigger injectors with the nos install. I know its a small shot, but do you think i will need the upgraded fuel system?
Assuming its a wet nos kit (and it should be) you will not need injectors. The fuel pump however is cheap and easy and should be upgraded regardless
Its wet (duh)... So the stock fuel injectors will be fine? Because I know I dont have to retard the timing with only a 50 shot. Do you think i will get a power gain if i dropped in the fuel pump?
i ran out of fuel pump 10 sec in to a run
you can feel the car go lean
the c1 cams go easily to 7000 rpm, way beyond what the stock fuel pump can feed
[you need about 29 gph for a fuel pump]
seems for a 100 bucks you could eliminate this nuisance
and the major risk of detonation using n2o
also, just my experience with your cam and combo
NA i run colder plugs
on nitrous, for safety, not power
i ran 5 gal. of vp 101 octane, race gas as well
2 step colder, short projection, copper plugs
help too
imo
the 50 shot kit i experienced, with the mods you listed
will cut over 1sec from your 1/4mile time
imo
this bird loves to giggle
i went sideways two lanes on a 100 shot
and stayed ahead of a gto for 10 sec,
i had no respect for a 50 shot
watch it
it's more than you think, added to the mods you have
thank you very helpful! I cant wait to actually put all this together, and try and race my buddy's stock 2004 gto. MOst likely i will still lose, but us sentra owners always know we spent a whole lot less. Rather than those factory beef cakes.
