1 - 14 of 14 Posts
Alright so a have fuel system upgrade. i have injectors and fuel pump out of a 08 sti. And a complete TSI Honda:crazy: turbo kit (8 psi). I know i am in need a custom build header and down tube. But not sure about the sti injectors and fuel pump are worth using. I'am running an Apexi Neo with a wideband setup. Just need some help with the fuel system setup.
How big are the injectors? pink 565's? They will work. How much boost do you plan on running?
im in the process of making a custom turbo manifold. its not hard. but if you have your A/C condensor still, then itll be near impossible to make a customs downpipe.. im taking my AC out so i can get a reasonable size downpipe in.
I have the original autoboost manifold with a custom 3" dp and kept my A/C still lots of room. I even have my stock fans and radiator.
08 sti injectors are possibly side feed. u need top feeds.. look into that and make sure your getting something u can use
Just buy a treadstone manifold and your set...o and i do think your injectors are side feed and like someone else put they need to be top feed....regular wrx 440's work maybe find someone to trade you...
I also have a apexi neo wired into my secondaries. i going turn the relay down to open when boost starts and see what happens. Engine mods consist of BSR kit and JWT stage 1 cams. Hoping to see over 300 on the dyno
Ac, stock fans and stock location for things is not a blocker for a large down pipe, it is a tight fit, but it eventually fits in there.
stock fuel system but have a fuel pump and injectors out of an 08 sti, not sure exactly what size the injectors or the flow rate of the fuel pump is.
1 - 14 of 14 Posts
