I could really use some help diagnosing my transmission issue. It has me at a loss.
It's a 2006 Spec V. I've changed various trans. parts about 6 months ago. A new clutch kit, master and slave cyl., and a 2jr used transmission with a new shift fork. It has many more aftermarket and new parts all over, but that's all for the transmission recently.
The issue:
Trying to start the car... I push the clutch in, make sure it's in neutral, and turn the key. The car starts normally, no noises, vibrations or smells. When I let off the clutch (still in neutral) the car jumps forward like I've released it in 1st gear.
What I've tried:
I've tried a number of things and haven't been able to track down the issue yet. I've checked the linkage attached to the shifter and it looks good and moves freely. The other end of the linkage attached to the control assembly on top of the transmission, also appears to be moving in response to the shifter. I haven't found anything stuck, loose, or disconnected.
My clutch engages and disengages, since I'm able to idle as long as I have the pedal depressed.
With the car off, If I place the car in gear and try to roll it, it won't roll.
If I place it in neutral, I can roll it.
Yet, it seems neutral disappears and becomes an extension of 1st gear once the car is started...
I've checked and topped off the gear oil with no effect.
No related codes popping up, and no real warning or issues leading up to this. I drove it home and parked it, and this is what I have the next morning... Any thoughts on what I can check from here?
Extra details:
***the only noteworthy things from the day before the issue began:
--I had just taken the car on interstate speeds (75-85mph ~30 miles each way) for the first time in months, but didn't notice anything "off" until the return trip. When I exited the highway, I noticed a very slight bit of trouble changing gears for the last 3-4 miles home. It didn't want to smoothly change, it took a second try as if I lazily, or too quicky changed gears without the clutch fully depressed. Wasn't enough to raise concern at the time. It struck me as an indication the gear oil was low or due to be changed.
--I was parked in 2nd gear on a flat driveway, and was lightly bumped from behind when someone else parked behind me. I didn't think much of it because it didnt leave as much as leave a spot on the bumper. I started it and drove 30 miles on interstate afterwards with no problems. Then parked it at home and here we are!
The issue:
What I've tried:
Extra details:
