1 - 14 of 14 Posts
thats a "dry" kit, you want a "wet" kit. if you have to ask what the difference is please do some more research before adding nitrous to your car.
oem injectors are fine, oem pump is up to the task but not recommended, kinda risky. all of this is assuming your not going to push more than a 75 shot of course.
Stock motor no more than a 50 shot. 75 is pushing it without copper plugs and retarded timing.
And do not use a dry kit.
zex sells the option
to"upgrade" to a wet kit
but they want 300 bucks for it
better yet
an nx or nos full kit
or if you insist on purple tanks [they make black too]
a full zex kit
like this
http://www.zex.com/zx/4-6-cylinder-efi-wet-blackout-nitrous-systemtmhtml/
on that page is a pdf file with the directions
download, read and decide
if this is somthing your interested in doing
imo
caution
very addictive fun
a 5lb bottle will never do
try 15lb
lol
NITROUS >:] random post of the day
If you wanted to run the safe shot kit, as it says on the site, you need your own fuel controller to add the extra fuel needed to level with the nitrous.
Wet kits are an easier way to bolt on a notorious system.
do they make them in pink?
I would have to recommend a nos fogger setup. bust most of all, controllers to run it, my set up works like a turbo with a programmable rpm window switch and a lean safety cut off switch. I ran it over a year straight without any problems besides running out devil sauce all the time lol.
the B.S. stop when the bottle runs dry.
I would have to recommend a nos fogger setup. bust most of all, controllers to run it, my set up works like a turbo with a programmable rpm window switch and a lean safety cut off switch. I ran it over a year straight with any problems besides running out devil sauce all the time lol.
1 - 14 of 14 Posts
