Hey, i need some help figuring out how to go about upgrading my car, what to do first, what i shouldn't even bother with, and what i haven't seen or thought of. I bolded all of the key points in case you don't want to read through it all and ill try to keep it short but i tend to over complicate things sometimes. sorry :thinking:
i have an 03 spec, just bought it and have done no performance mods to it yet besides headers (probably ebay) and some disgusting catback that needs to be replaced, I've also done the butterfly screws, i got in a big legal mess with the title so i wont have it in my name until January 10th but i'm saving all of my money to do some upgrades through winter and then hit it real hard when tax season comes
It currently has a replacement QR from an 03 Altima in it but i honestly don't know the exact mileage. On the receipt for the swap i got with the car it says it had 84k on the replacement motor, but doesn't show the mileage that was on the spec when it was swapped. Right now i'm at 154k, the kid said he only put about 30k on the motor which would leave it at an estimated 110k but i don't really want to take his word for it..with that being said i'm not sure if i want to push its potential too far
The spec is my daily driver but i'm a kid, and i'm a speed addict, so i'm not looking for huge track potential like most of you go after, just want to have a clean, fast car that i can beat all of my friends with and still drive to work and back. (examples of the cars i want to go against are a Mark 4 and a Mark 5 GTI, a rabbit, and an A4... I have already beat an 09 corolla sport, a vette, and a couple hondas :47: )
Here's what I was thinking about doing to it: (performance and aesthetic)
*BSR removal
*pop charger or short ram (i live by the great lakes where its always wet or snowy and dont trust low hung CAI's)
*short shift
*light weight pulleys
*ECU flash
*Secondary Butterfly ECU switch mod
*14lb fly wheel
*stage 1 clutch
*throttle body spacer
*aluminum radiator
*apexi catback (have to look up other systems, i personally dont think any exhaust tip looks good coming from the car so i might just cut it back)
*coil overs
*plastidip paint job (my clear coat is chipping)
*04 rear bumper swap
*projector headlights
*new wheels (flush) probably a 17x9 +25
*yoko580's
I'm sure there's some things i'm forgetting but i was hoping you guys could help tell me what to do first, what is most noticeable, and what i should avoid wasting money on.
I REALLY want to turbo it, but i don't know if it would be smart with the mileage.. do you think i should turbo it and keep it at low boost? or would i need to do a rebuild first..or even a new motor?
i love the idea of dropping a new QR or a VQ into it, but i will be progressively upgrading, although i could just save up, and drop it all in at once later in spring..
*BSR removal
*short shift
*ECU flash
*14lb fly wheel
*stage 1 clutch
*aluminum radiator
*coil overs
*yoko580's
