1 - 2 of 2 Posts
A bit confused, my horn randomly stopped working, figured it was the horn itself so i bought new Hella brand, hooked them up via relay provided, and just the single horn wire, both didnt work. So i checked fuses all good, and changed the relay 3 different times. So i figured maybe a loose wire under the steering column cover, nope! Maybe clockspring? My cruise control works fine, and no airbag light, i guess these were problems people were having here from what ive read. No power to the horn wire either. Im stummped? thanks!!
Its most likely the clock spring. No srs or cc has to be effected if its just the horn wire in the ribbon cable. Thats really the last place it can be if its not the horn connection itself. Pull the airbag off and see whats going on. If you have a test light see if there is power coming out of the connector from the steering wheel. Thatll also tell you if there is a broken wire to the horn.
1 - 2 of 2 Posts
