1 - 20 of 20 Posts
When my clutch was installed, it was noted my catch can was full of a watery oil, and weird yellow stuff.
It's been 2.5 weeks since then, so I figured I would take another look. My catch can was half full, with what looks like water almost. It's thin and has the consistency of water, with a little brown color. Then there is this thick goo/paste everywhere too.
I was curious what kind of junk people were finding in their catch cans, how often they clean them out, and how are you cleaning this stuff?
This is what I found:
I went ahead and poured some seafoam into the can and shook it up, dumped it out, poured some more, shook it up, and dumped it out. Doesn't really look like it did a whole lot, but I did get more of the goo stuff out.
Discussion Starter #2 (Edited)
It's condensation. Kinda goes hand in hand with having a can, I got a rather large catch can on mine and i didn't drain it all winter while the car was sitting in the garage, opened up the drain a couple weeks ago and the thing was almost FULL of water. No need to worry bout this "stuff" happening in your engine tho just keep the CC drained and you'll be good
If you have a lot of blow by, you can find old broken down fuel in your catch can.
Sent from my phone. Who cares what it is. They all do it now-a-days.
BDSF
I get the same gunk in my home depot special cc. Going to be upgrading to a Saikou Michi can before the s/c goes back on though... only downside is I don't have a vacuum source to pull blowby through the cc, so the other end just vents to atmosphere. I'd probably get a lot more crap if I did.
Sammy, your pcv is gutted correct?
BDSF
Brakleen should do the trick. Do you have any media in the can filtering out blowby?
Discussion Starter #12
You could throw it in an ultrasonic cleaner for about an hour. If you have the time, go for longer. If not, 15 minutes will get most of the big shit off.
Go Tarheels! Go Panthers!
I wish I had found this before I got rid of my supercharger, but I have recently found a possible cheap solution to this vacuum problem. Turbo, supercharged or NA can use this trick too. I read a post on the GNX forums where they took a smog pump off an LS1 and modified it into a crankcase vacuum pump. New these go for around 100 bucks, but can be had around 15 bucks from a junkyard. Im gonna see if I can find one this weekend to go on my race car. Kinda off topic but its kind of related. Ill start a new thread on it if I can find one.
BDSF
Please do!
Cleaned out my dual Saikou Michi catch can last weekend.
Been about 12 months and this is what was in it from the PCV line. Close to 125ml (4oz)
Can on the air inlet line was clean. No blow-by from WOT.
on Flickr
Doing it's job nicely.
1 - 20 of 20 Posts
