1 - 2 of 2 Posts
What exactly would I need to install a T in the wiring to the running lights on a 2000 Sentra GXE 1.8L?
I need the male and female connectors to make a jumper between the harness plug that goes to the turn signal / running light and the light.
Does somebody aLREADY MAKE SUCH A Wiring harness tp run back to a relay?
scotch lock connectors are probalby the most common way to tap an existing wire (other than just exposing the wire and looping it around.) That or solder if you have an iron.
1 - 2 of 2 Posts
