21 - 29 of 29 Posts
It's under EC. All the way to the bottom. You'll see it Corn. Also it's all the same for the years.
Black/red goes from the FP fuse to the control side of the FP relay.
Black/white goes from the FP fuse to the supply side of the FP relay.
Black/purple goes from the ECU to ground the fuel pump relay.
Black/yellow goes from the supply side of the FP relay to the pump. (Pin # 1 from the pump connector)
Black is ground for the pump. (pin# 3 from the pump connector)
No its not. 2002 doesnt have those color wires, we have from left to right is black/yellow , green , black green/orange , black/white
Haha yeah it looks like someone ran a wire to prevent overheating or something, with the wrong logic in mind.
Looks like your wires are the same as mine. Ignore the upgraded power and ground lol
This is on a 2001 Sentra SE
So my question to you is did you tap into the green/orange for the signal ? I tapped into the black/yellow for the power to relay. One wire is going to a ground at chassis. One wire is going to inline fuse wire to battery and the other I'm guessing goes to the signal for the pump which is the green/orange?
Product Audio equipment Electronic component Material property Font
Thats may be the key on switch to the fp. Dont quote me on that but I think thats right.
21 - 29 of 29 Posts
