1 - 9 of 9 Posts
Clean the maf and throttle body, so both relearns and check for vacuum leaks to start as you may have a cracked hose.
Are you throwing a code/ check engine light?
The code is p1706 neutral position switch .Maf is brand new and did clean throttle body and did the relearn.Have not checked any vacum leak yet
You did both relearns?
Looking at the FSM and it looks like either the harness is either not connected or shorted, or the switch needs to be replaced.
Its likely a throttle body relearn. A p0171 would come up or can see by fuel trims.
Have to do the difficult idle air volume learning procedure correctly and also throttle valve closed position relearn, when cold.
Discussion Starter · #6 ·
yes, did the relearn part with the engine light flashing and within few seconds light become steady and start the engine,it didnt help. also when driving the car and rolling in neutral the rpm goes between 1500rpm and 3000rpm in neutral .
You still need to do the throttle body relearn, completley different process. All you did was the maf relearn and it sounds like the TB needs the relearn especially after cleaning.
Yes. Search it. Its common and a real bitch to do correctly.
Discussion Starter · #9 ·
Thanks all,the high idle is fixed and back to normal. i did the vacum test and smoke was coming out the pvc valves
1 - 9 of 9 Posts
