1 - 13 of 13 Posts
· The Watcher
NATS and its part wiring (kinda) and mostly ecu IIRC, works with the ignition signal and key. Don't know how to test as I don't have NATS. You can't replace the ignition switch alone but testing it would be your first start unless your key is having issues.
Search for the FSM link if you want to dig into yourself.
· The Watcher
Bad images but on the outside of the block is the T tab looking things, acts like a plug all around it.
Rectangle Schematic Font Parallel Engineering
Schematic Parallel Technical drawing Rectangle Engineering
· The Watcher
Check your cam position sensor, if that's bad it won't send a signal for the coil packs... should be throwing a code.
· The Watcher
Timing is off, will have to tdc the motor and reset the intake cam. This will cause a no start as well.
1 - 13 of 13 Posts
