Do you have any pictures of the replacement motor? QR25’s with plastic manifold’s like the ones found in B16 Sentra’s, Altima’s, and Rogue’s don’t have the same mounting points as QR25’s with the aluminum manifold’s like the ones from B15 Sentra’s or Altima’s. There’s also JDM QR25’s with direct fuel injection that have a plastic manifold and those aren’t a direct swap into a B15 Sentra either. This is what it looks like so don’t buy it if it looks like this:
Best bet is to get a motor with another aluminum manifold just to make sure it’ll be an easy direct swap.
I have a Spec V and I did a JDM motor swap this past summer, so I can help you out if you need anything. When I pulled the motor, I had to pull my transmission with it because there wasn’t enough clearance to get the motor by itself. I basically had to bring the both of them to a vertical tilt to get them out of the engine bay, and then move the transmission to the new motor. I removed as many parts inside the engine bay as I could before pulling the motor itself. I took lots of pictures before and as I removed parts so I could remember where they were. I also put hardware into ziplock bags and labeled where they came from.
Before my engine swap:
This is my JDM motor below. I removed my aluminum intake manifold and installed an Altima plastic plenum with 2J-Racing’s adapter kit.
Some pics from the tear down:
