1 - 20 of 148 Posts
Well here we go finally. Have an 04 spec v. I've had it for about 3 years maybe more. I've wanted one since they came out while I was in highschool. Just did my first motor swap in it couple weeks ago. I put a built motor in and plan on goin boost. I'm currently in the process of acquiring a turbo kit.
Mods so far
Boosted on August 17 2017
Custom manifold and downpipe, tial wg, hks bov, tr8 intercooler and 2.5" piping, 850cc injectors, Garrett gt3076r bb water and oil cooled, 4" intake
Motor - low compression pistons, K1 rods, B16 crank, Bc stage 2 cams, bc valves and titanium retainers, Bsr kit, lower temp thermostats, and a 2j Ps pulley 2j rad and heater hoses
Transmission- 03 spec v transmission, spec stage 3 clutch, 2j 14lb flywheel, 2j sts and bushings, 2j v2 shift knob
Suspension- Bc 9k coilovers, Nismo fsb, rsb, and strut bar, 4pt trunk bar, 4pt tanabe front brace, 2j 15mm alks, 2j crossmember bushings, weapon r torque damper, tdmi qt link, tdmi hard race control arm bushings, 2j solid motor mounts
Exhaust- 2j 3" v3 resonated midpipe
2j 3 " Medusa catback
Brakes- 300zx bbk 12.75" rotors
Brembo rears
Misc.- greddy ad panel, 2j rad cap, 2j dress up caps, complete 02 spec v interor, 2j 20mm spacers all around,2j 82mm studs. Grounding kit, 2j yellow fogs, 02 spec rims custom painted now on 17x8 et35 5zigens
With 255 40 azenies
I'm sure there more can't think of it all now but there will be more to come. Pics will be added soon also
Cpl months after I got her bone stock
How she sits currently
:gives::sucks:
:troll:
:lmao: JK
WHERE'S THE PICS?!,!??! :pics:
:troll:
:gives::sucks:
:troll:
:lmao: JK
:troll:
There some pics for you. Was waiting for someone to post something so I could do it threw Tapatalk. It's just easier that way
Looks slow :troll:
Flame Videos!!!!!!!!!
Do It Myself!!!! :eek13:
Just because I Won't drive it doesn't mean I can't drive it faster than your VQ if I feel like it! :drive: :troll:
U say that, let's run them from a dig
lol
in the 300hp catogory
i find they turn the approx same times
vq 316hp @7.83
qrtaf [email protected]
at the same slippery track paradise
vq on slicks
qrtaf on 275/40 r 888s
only at 360 hp and above
will imo beat the vq in the 1/8
qrtaf just doesn't have that forward cylinder bank, which loads the front end
giving the vq an advantage in 60ft times
imo
lol
vq 316hp @7.83
vq on slicks
imo
with that logic, we should be able to add weight to the front end for the quarter milers and they should be able to get better traction.... or would the extra weight slow it down? I would think that for the same hp, the added weight will keep it from spinning a bit...might be something to think about, add 50-75 pounds of lead to the front frame rails?
well if u think about a vq only weighs about 50-60lbs more u add all the turbo stuff to a qr ur pretty close to the same weight
at one time i filled the front bumper guard with concrete
used 37-60lb batteries
then i switched tactics
raked it nose down to get 60% of the weight on the front end
used 23" slicks and 26" tall rear tires in addition
and lightened the battery to 11 lb
this helped na
but the turbo is different
and may need more weight up front
there is little difference imo
in dropping boost and power in 1st to gain traction
and adding 30lb to the front end
fill the water reservoir [spray] adds 6 lbs to front end
use the heaviest battery that fits
but doing this on a good track
immediately broke the stock axles at 360hp and 370 ft lb tq
but mighta gone into the 1.6s for 60 ft
at a good track
fyi
vq started at 3150
after stripping but with roll cage
came down to 2900 lb
turbo weighs
with slightly lighter cage
p20160516_121207 by Barry, on Flickr
what difference are you talking about
lol
mine weights the same with the vq as it did with the turbo setup, even a local who had a vq swapped weighed in a 2550
1 - 20 of 148 Posts
