L8YBUG 2/Turbo QR25 B13/ Mpls, MN
120836 Views 925 Replies 57 Participants Last post by  Awdb13
10
Mod List:
Darton Sleeved QR25
SS o-ring'd deck
B16 crank
Wiseco 10.4:1 pistons w/ Heavy Duty, DLC coated wrist pins
Pauter Rods w/ 625+ hardware
ARP L19 Head Studs
ARP 2000 Main Studs
BC valve springs/retainers
ATI Super Damper
PNP head
Precision 6266 gen2 turbo (740whp/560wtq at ~31psi)
JWT C1 cams
RPS BC2 carbon/carbon twin disc clutch
AEM Infinity
AEM CD-7 display
BC coilovers 12k front, 18k rear
Keizer Verbrand 13x11 fronts, 15x3.5 rears
Whelp, as some of you may know, my pride and joy took a tumble. Rolled her about a month ago so it's time for bigger and better things. I've had a B13 SE-R for a couple years now sitting in my yard waiting for a drivetrain. I've had plans to do a 600whp QR build and swap it in but have never had the money to buy a donor car for all the parts. Now it seems I have an entire drivetrain in my garage so I'm getting underway! The plan is to install rods/pistons this winter and run stock sleeves and stock cams for now. I'll only be pushing about 450-500whp for the time being cuz I don't wanna prolong the process by having to pay for and wait for sleeving.
I already have the engine and trans out of the b15 as well as the subframe. Within the next week or two I'll start on fitting the subframe. I'm extremely thankful 2JR decided to do this swap and confirm that it's not all that in-depth cuz I've had this plan since before that was even done just didn't quite know how I was gonna go about it.
Here's progress pics so far.
Screen Technology Electronic device Display device
Land vehicle Vehicle Car Automotive design Exhaust system
Engine Auto part Vehicle Car Automotive engine part
Land vehicle Vehicle Car Sedan Coupé
Land vehicle Vehicle Car Coupé Sedan
Engine Auto part Vehicle Car Custom car
Land vehicle Vehicle Car Red Alloy wheel
Land vehicle Vehicle Car Bumper Auto part
Vehicle Motor vehicle Car Grass Automotive wheel system
Vehicle Tree Car Tire Automotive wheel system
Things modified for others' reference:
Cut front mounting perches off B15 K-member
Enlarge existing holes at front k-member mounting points
Remove outer studs from B13 chassis at front k member mounting
Bolt B15 k member to front, inner mounting holes on B13 chassis
Center k member and drill holes thru floor for rear k member mounts
Modify B13 upper strut mounting holes to accept B15 strut mounts
Remove B13 passenger engine mount from body (5 spot welds and body glue)
Mock up side mounts on engine/trans and set in car, mark and drill holes on frame rails (only using 2 on the pass side), then weld in shoulder bolts upside down to create studs
Drill holes in side of driver frame rail and weld in shoulder nuts
Mark area in pass frame rail that needs notching to fit power strg
See less See more
901 - 920 of 926 Posts
Did some laundry last weekend.
Reactions: 4
Finally got my hands on some new swag! Check out the new V1R hats at www.VisionOneRacing.com/shop
Reactions: 2
You should post a pic of said torque plate. I've been looking into having one made for awhile.
Sure are getting her dialed. Unfortunately messed up a valve before we could turn it up and she was dropping boost quick.
Went 9.95 off the trailer at 24psi and in the semi-finals had to settle for a 10.0 on only 19-20psi.... Probably only about 550whp or so
That about does it for the 2021 season, but we'll get her fixed up and come out with that 35+psi tune next year and see what she can really do.
Might have some other surprises coming out soon too....
Receipt Handwriting Font Material property Rectangle
See less See more
Reactions: 4
Just gives you time to make more parts for us (me)
Reactions: 2
Such as this...?????
Gonna print this bish out and see how she fits.
Bonus points if you can name the component...
Automotive design Eyewear Automotive lighting Triangle Automotive exterior
Tool Gas Household hardware Camera accessory Auto part
See less See more
Reactions: 1
Like the description says, a cuff lol.
To keep the transmission sturdy
  • Haha
Reactions: 2
Yeah I didn't fully think that through when attaching the file name lmao
Reactions: 1
I still need to order your springs still..maybe I’ll order both at same time and drop it on over winter
Haha, no worries. Give my brother a dollar off his next order, or some stickers/swag, Gregory Conway.
Reactions: 1
Stickers come with every purchase lol
Reactions: 1
Keeps the Transmission cables closer together, less slop?
4
So I was finally able to get a fender pulled from the mold... This bitch is coming together quite well!
Enjoy....
Car Tire Land vehicle Wheel Vehicle
Automotive parking light Wheel Tire Car Vehicle
Wheel Tire Automotive parking light Car Vehicle
Tire Wheel Automotive tail & brake light Vehicle Sky
See less See more
Reactions: 1
She gonna look fire. And that’s the number 1 question asked at the track to me. U running a sr20 in that lol.
side note that’s a really nice fire house too
They built it brand new this year, and every time I drove by I thought "DAMN, that would be a killer spot for some photos when the front end is finished"
In the process of relocating so I needed to get a quick photo shoot in before I pack things up lol
Reactions: 1
I would have done the same thing? U moving to east coast to be by all the racers lol
Something like that lol.
Let's just say... "Sunshine" will be plentiful
Reactions: 1
Lol, sunshine and hurricanes or sunshine and earthquakes?
Fuck California...
Does that answer your question? lol
Reactions: 3
