I know there is a list of mods, parts, and what not for newcomers, but this thread is not just a list of stuff for sentras. Yogi, others, and myself sorta did this on a noobie's thread when the question was asked "What else can I do for cheap?" So I'm trying to organize it so we can have just 1 quick link for people to use when they introduce themselves and have that question.
For example, instead of 6 people thankfully piping in on a welcome thread with suggested first mods, we can say "go here link."
The other goal here is to keep the $$$ to a minimum. This will eliminate things like headers (aftermarket), lowering springs, and so on. Yes they are definitely necessary, but not for the goal of this thread.
I will edit this several times I'm sure, but for now we'll start 1 list that will stay at $100. These are in no order of importance necessarily. Some of these mods might be less depending on if for example you have loctite already. That mod would then be free. I'm assuming the cost of the supplies in these prices.
11-6-11 UPDATE
As I forewarned, the list would need several revisions so here is a moderate update. I have included a new section, or list rather, that is more cosmetic based. So basically we have 3 lists: A "performance" list with several performance mods that will roughly total $100, a "cosmetic" list that will include basically everything not performance related, and a third list of single items that are typically sold for less than $100 a piece. Again, nothing is listed in an order of importance and as stated the goal here is cheap, cheap, cheap. This list will always grow so your opinions and input are highly valued for the greater good of the b15 community. Thanks to everyone who has contributed to this.
PERFORMANCE RELATED MODS
1. Loctite Butterfly screw mod $4
2. All B16 Models - Remove/Gut Stock Exhaust Manifold (07+) $0
3. Throttle body bypass $0
4. All B15 Models - Motor Mount Inserts $50
5. $4 wheel hop aid $4
6. Balance shaft chain cut $6
7.$9 short shifter $9
8. 02-0 sentra knock sensor relocation $10
9. Seafoam $9.99
10. Skateboard shifter bushing mod (no link) $5
11. How to clean MAF Sensor…With Pics $5
TOTAL=$102.99
COSMETIC RELATED MODS
1. All B15 Models - Fog Light Mod
2. Dash Light Conversion Tutorial
3. Fix Squeaky Clutch
4. HOWTO: auto A/C switch mod
5. How to Fix foggy headlights
6. Blacked out tail lights
7. Paint Emblems (the right way w/PICS)
8. renewing rusty window sills !
9. Clutch Switch Bypass
10. How To: Install Custom Cup Holder
11. Make a Front Lip
12. $3 Radiator Rubber Bushing Mod
13. Keep your rotors from rusting
14. All B15 Models - How To; Make Your Own Speaker Spacers from Stock Speakers.
15. How to: Make a custom mesh grille
16. 04-06 - Remove, Modify, Fix Reverse Lockout
17. E-brake (Parking Brake) Adjust
18. How to: Cheap yellow fog lenses
19. How to: Make spoiler gaskets
20. All B15 Models - How to make E-BRAKE TIGHTER
21. How To Reuse THe Old Speaker Bracket For New Speakers
22. Make a custom front splitter from ABS plastic
23. How-To: 00-03 Retrofit HID projector headlamps and yellow fogs on the cheap
24. All B15 Models - Install Nissan Rogue Hood Struts
25. http://www.b15u.com/threads/exterior-modifications-paint-bodywork/18627-accord-lip.html
After considering what has been suggested by the feedback, a 3rd list is below for items that are less than $100 each and several are MUST have items for improving the b15. I did not list prices because they can change like the weather. Again, no specific order, just listing them as they come out. This list too will grow.
PARTS FOR UNDER $100
1. 2J racing anti lift kit (ALK)
2. 2J racing brass or aluminum shift bushings -or- FI-R nylatron shift bushings
3. 2J racing 5mm, 10mm, 15mm, and 20mm wheel spacers (1 set)
4. 2J racing rear trailing arm bushings
5. 2J racing bump steer kit
6. FI-R d.i.y. QR to VQ tb kit
7. FI-R nylatron cross member bushings
8. Ultra Racing front strut bar-upper
9. eBay stainless steel or ceramic header
10. eBay short ram intake
11. Jim Wolf Technologies balance shaft removal kit.
12. http://www.b15u.com/threads/sentra-...hnical-info/21347-how-cooler-thermostats.html
13. http://www.b15u.com/threads/sentra-...s-technical-info/15946-how-oil-catch-can.html
14. OBX or 2J racing lightweight crankshaft pulley.
15. http://www.b15u.com/threads/sentra-...wrap-your-exhaust-dp-header-exhaust-wrap.html
Feedback welcomed
11-6-11 UPDATE
9. Seafoam $9.99
TOTAL=$102.99
Feedback welcomed
