1 - 10 of 10 Posts
http://maxbore.com/
Got my TB back from Max Bore today, cleaned up real nice and a noticeable difference overall to the one that was on.
Some measurements from the front from the the deepest my calipers could go to the the outer.
Front:
Rear:
Works so far at idle with complete relearns minus resetting fuel trims, though haven't driven yet.
I want to know how this turns out, I'm on my second TB and again with high idle problem. I already check the maf and that got replaced twice too....
Discussion Starter · #4 ·
Sounds like you have other issues with fuel or vacuum if the regulations are not working, getting the tb bored isn't going to fix it.
Alright, because the fuel pump was replaced last year. And how do I find a vacuum leak? Since search doesn't work.
I am going to try to do relearns again see if that will help it, because it was working fine for about 3 weeks before I got the check engine for high idle. And it high idles once the car has been running for about an hour total in the day, if I drove less than total if an hour, for some reason it idles correctly.
@CrickiKaze what did they charge you to have that done?
Discussion Starter · #7 ·
Leak would be in/around hoses, I wouldn't do anything with out knowing the code as it may have specifics that you are not looking at.
$170 with some extra stuff.
Link in the OP.
If I remember correctly it throws p0507 and I remember when I got the code, auto zone said I am gonna need a new TB last year. That's what I got a new TB. At around Feb this year I got an engine from an importer that gets them from japan with like around 65k-80k miles. I am hoping the mechanic did not clean the TB. I did reuse everything except coolant hoses. I am waiting on a bafx obd dongle to see if it throws any other codes out this Friday. The last time I did the pedal dance to get the codes was about 3 months again and only throws out p0507.
1 - 10 of 10 Posts
