Hello all.
I have 2004 Sentra SE-R SpecV with a six speed manual transmission with about 93k miles and about two months ago I changed the factory exhaust manifold with an aftermarket one by SRS as well as doing the spacer modification for the second sensor on the bottom. The engine does not throw any codes but I'm having trouble figuring out what is making an odd sound. When I decelerate around 3000 rpm it makes a winding down grinding sound that i can't make it do while its out of gear. I was told by the previous owner that the clutch was replaced before i bought the car two years ago. The clutch doesn't slip or I at least don't feel any sign of being worn out. Also, when its parked and i rev it to about 3k rpm the exhaust makes a popping sound sort of like a backfire when i let go of the gas. I didn't want to change the sound of the car or do too many modifications to the vehicle since it's my daily driver and I didn't want to invest too much money into the vehicle in general. Any advice would be welcome. I usually do the work on my vehicle but this is the first manual I own and I have never worked on a transmission before. Thank you all for listening.
