Hi all! It’s been a while. My turbo spec v has been sitting for a while because I was annoyed with fixing it tbh and now I’ve decided to revive it. I’m at a loss as to what It can be.
Basically the car idles fine. But as soon as you give it even 1/4 throttle (in neutral) it has a huge delay and feels like it’s running on 2 cylinders. No codes. But afr are reading super lean. It’s undriveable.
I’ve done the following to remedy the issue with no success:
-new plugs
-new maf
-new cam and crank sensor
-new intake manifold gaskets
-cleaned out the injectors
-pulled 4 coil packs from the junk yard
-check cam shaft timing marks
-smoke tested for vaccuum leaks
-did all the pedal dances.
-compression tested it
before I go any more parts cannon I figured I’d reach out to y’all for help
-new plugs
-new maf
