1 - 11 of 11 Posts
ok soo i have an 03 spec v tuned by uprev did the conversion gas pedal gauge cluster wideband ect. having problems switching maps. Read to hold cancel on cruise control and tap brake to desired map and set light shoukd flash . my cruise control works gauges work but maps wont engage anyone have any info?
One of One???
Yeah, I have an 04 that doesn't have maps. It happens sometimes. You can still use a computer and a cable to change maps. If you have the cable.
Discussion Starter · #7 ·
yes i have uprev cable how do you do it,and i bought my ecu from 2j but had it re tuned and i believe its an 06 ecu could be wrong but its an r4 ecu
I have a 06 with 2jr reflash. I do know the 02-03s need a form a conversion kit for it to work.
Administrator
Would have to look at the FSM to verify that.
1 - 11 of 11 Posts
