1 - 5 of 5 Posts
Eventhough I have a new fuel pump on my 1.8L, I still have to turn the key 2 or 3 times for the engine to start.
Ideas anyone?
only things i can think of off the top of my mind is check the coil packs, battery, compression. also is fuel pump factory oem or aftermarket?
Eventhough I have a new fuel pump on my 1.8L, I still have to turn the key 2 or 3 times for the engine to start. Visit Autoguysland to find the best OBD2 scanner that you may concern.
Ideas anyone?
It may be leak of fuel pressure valve. If there is a leak, it makes the fuel pump work harder and takes many times to start engine.
1 - 5 of 5 Posts
