1 - 3 of 3 Posts
Hey guys,
Just got an 05 spec v. Previous owner had quite a few things done to it already. Here is the mod list:
Suspension:
Koni Yellow Shocks set at 55%
1.5in drop Lowering Springs, Rates: 308lbs.in Front / 291lbs.in Rear
25MM Front Swaybar
25MM Rear Swaybar
Delrin Solid Motor Mounts
Delrin Crossmember bushings
TDMI rigid collars
Brakes:
Perfect stop scorched ceramic pads Front&Rear
Brembo Blank rotors
Has rear Brembo package large rotor size and caliper bracket
Drivetrain:
JWT 12lb Flywheel
JWT Heavy Duty Clutch/Pressure Plate
Nismo trans mount short shifter
Self lubricating shifter bushings on both ends of the shifter cables
Engine:
AEM SRI
Intake Plenum spacer
07+ b16 QR25DE Intake Plenum
Hondata Thermal Intake Manifold Gasket
Gutted precat
3" catback
Apexi WS2 Muffler
Cooling:
Koyo Radiator
Koyo Radiator Cap 1.3 Bar
two 12" SPAL fans
Here's one but it isn't a very good one. I have yet to get some good ones. I want to get her detailed first haha.
1 - 3 of 3 Posts
