1 - 20 of 32 Posts
Im getting my nitrous kit tommorow and im going to be installing.it
The general thought it.to put the fogger about.6 inches from the throttle body but I have a spacer and I was wondering if anyone has tapped a throttle body spacer for nitrous
Sent from my Dell Streak using Tapatalk
Its my understanding you REALLY dont want to do a fogger system in our cars.
Ive read that WET is the way to go.
"I see a cool air intake with a Nos fogger system and a T3 turbo Dominic. It has direct nitrous injection..."
"Yeah and a stand alone fuel management system. Not a bad way to spend $10,000 dollars."
"You see this sh*t?! He's got enough Nos to blow himself up period!"
Yes it is a wet system I wouldnt run a dry shot.on this motor
Discussion Starter #11
No rmp switch so far just an arming.switch and 2 pushbotton switches ill probably use for.the.purge im gonna start wiring it up today im gonna need some help with the relay wiring
Also im planning on running.an.rpm/tps switch looking for suggestions to.order this week and idk what jets are in the fogger now but im gonna have to.order a few of those too I want to start with just a 35 and work to 75
Discussion Starter #12
Discussion Starter #14
Alright cool I need some help.with figuring.out jets
I want to run a 35 shot to begin with also are jets brand specific? As in I should purchase just nos.jets or.will nx and zex work
nos jets wont work with nx or zex nozzles but zex and nx are the same kind of jet so they are interchangeable
Discussion Starter #16
Im having an issue I wires up my purge solenoid and wired up my switches
Once I crack the bottle.loose it comes straightnout the fogger and I dont even have the n20 or fuel solenoids wired up wtf
When you look through the inlet of the nitrous solenoid, can you see through it? If so, it's time for a serious inspection/rebuild. They should normally sit completely closed until power is run through them.
1 - 20 of 32 Posts
