Hey guys,
So my spec v has a koyo radiator and 2 Spal fans that were installed from the previous owner. When I start the car neither fan is on (obviously). When I turn the AC on, the compressor turns on and then the passenger side fan turns on. When the car gets up to temp, the same fan will stay on regardless of AC. The driver's side one doesn't seem to turn on ever. The AC is nice and cold when it works but if I'm idling for awhile, I hear the compressor shut off and then it gets warm until I start driving again. After reading through many threads and forums, it could be a number of things, a bad relay, not enough refrigerant, or bad wiring in the fans. I wanted to see what any of you thought for my exact problem as I couldn't find this exact issue anywhere with a specific answer. Any help is appreciated!
