1 - 11 of 11 Posts
sry unsure what else to name this, seems nissan doesnt sell pigtail connectors,will an aftermarket one be alright? i dont need fan pigtail, looking for what the fan pigtail links to( wire harness pigtail) female connector is without prongs right?
Connects directly to the fan, if you want a harness connector you can get 2j's or find it.
not from fan to harness, from harness to fan, i have 2 from 2j coming but yea those are from fan to harness, unless im mistake an the 2j ones can work on either side?
really didnt wanna goto a junk yard but may be best option, unsure if anything but oem will be ok, hate messin with wiring 🤦‍♂️
lol yea, jusy wanted to check around before the junkyards open up today maybe i might get lucky n come across something descent to grab while im out
Finally remembered the place I ordered connectors from, they may have it in stock you just have to look.
Reactions: sampson384
ended up grabbing 2 sentras an 2 altimas fan pigtails, same engine and such, same years
just need to double check, but the pigtails i grabbed, i can use either correct? 1 is from a Sentra 2.5L an the other is from a Altima 2.5L, not manual tho, just wanted to make sure rewiring either into my spec wont cause any issue or damage?!? if anyone can help thanks much
Assuming the harness connector is the same on the altima, you will be fine as long as it's wired in properly.
Discussion Starter #11
putting aside the wires being different colors ....both i pulled are from qr25de 2.5Ls, now 8 just gotta figure out what the grounds are again an such then i can solder up an fix this wiring issue, thanks much
1 - 11 of 11 Posts
