Ok I cannot find anything that tells me what wires are which on the fan I know it has a low and high speed and I'm looking to wire both fans on high speed to a toggle switch I can figure it out with a test light which wires have power but would save me time if I knew which color is which since I couldn't find a diagram with this info
171988
Do you the FSM download and the right section cause it's in there.
There also a write up on the forum if you had used the search bar youd find it
When I search for that the page says oops we ran into a problem loading the page or something of the sort I've been trying for 2 days
There is a lot of "broken" links. I would look at my FSM but the wire color looks different than mine I think.
Driver side fan = green & blue wires are +
Passenger fan = green & yellow wire +
Reactions: juanfo and Marlyn
