1 - 5 of 5 Posts
I would like to know where the rear cover plate is located in a b15 automatic tranaxle.
J
What year and engine is this on? Also what do you mean by rear cover plate? Download the fsm. www.nicoclub.com/fsm
2002 nissan sentra ,when removing the oil pan it is said that if its an automatic vehicle the rear cover plate has to be removed,I would like it location please. Thanks
It should just be a small steel plate that covers the lower side of the flywheel. Its like 2 bolts. Might even be missing if removed before.
Oh you mean the flexplate/clutch inspection cover. Yea it should just be 2 bolts like sus spec said. It's usually located at the bottom of the bellhousing where it bolts up to the engine.
1 - 5 of 5 Posts
