Alright so I need a little bit more information before I go and start ordering parts. My Spec at two secondary intake valve screws - I was told at the time of purchase that they had been serviced and fixed but take a look at my showoff thread for more info http://www.b15u.com/member-rides-project-cars/20225-nerdbot-04-sunburst-spec-v-regina-sk.html to see that I was naive to believe it. After a few phone calls I learned that they were NEVER serviced under any kind of recall.
I will be going the same route as Karl - MisterNuts with a RevAuto S/C. But first I need to rebuild, obviously.
Following Karl's build as a near copy cat:
Revolution Autoworks supercharger kit - In the works, I'm awaiting the kit to be off to send payment
ATI Procharger C1a supercharger - Included via kit ^
2.25" pulley, 12-13psi @ redline (no boost gauge, no care) - A boost gauge is being supplied with the kit
Rev Auto 3" in/out intercooler - Included with said kit
Rev Auto 2.5" hot side, Custom 3" coldside piping - Included with said kit
TurboSmart Kompact diverter valve - It will be a Greddy RS BOV included with said kit
FIC 525cc injectors - STI 440CC Injectors with said kit
Walbro 255lph fuel pump - With said kit
OBX 4-1 header, ported, wrapped and sprayed with Thermo-tec products - I will continue to use my HotShot and it will be wrapped as well
Stromung 3" midpipe w/Vibrant high flow cat, heat wrapped - I currently have the same midpipe, it will also be wrapped
Stromung 3" catback exhaust w/Aero 14" resonator - Right now I have a mandrel bent 2.5" exhaust, it will probably remain.
Unorthodox Racing crank pulley - Knock off pulley, OBX. It works fine.
JWT BSR - I cut the chain instead
Ported and polished intake manifold by DPR Racing - I will most likely be getting mine done by CORNDOG
Ported and polished throttle body - Most likely will not be happening.
Designed Chaos throttle body spacer, port matched - Not going to do.
Mishimoto aluminum radiator with Nismo cap - I may stay with the stock rad.
Mishimoto 12" fans, pusher style Diddo
Mishimoto silicone radiator hoses Diddo
Stant low temp t-stats (170*/195*) - Stock thermostat - any insight or other suggestions, please note!
Throttle body coolant bypass - This is done already
Hondata intake manifold gasket - Maybe. I will most likely use the stock gasket.
ActiveTuning ground wires - Poormanmods FTW
Innovate LC-1 wideband - Included with said kit
SAFCII tuned - Included with said kit
NGK Iridium IX spark plugs, one step colder
Mobil1 0w40 - I live in Canada. I will be running 5w40.
So far I am looking at:
Import Performance Parts - Nissan HP Engine Kits Kit # 22 which includes:
Complete Gasket Set
MLS Head Gasket - I will be using an AJUSA head gasket
Wiseco Forged Pistons
(89 Bore) and
(8.5:1 compression)
Plasma Moly Rings
Performance Wrist Pins
TOGA HP Main Bearings
TOGA HP Rod Bearings
Thrust Washers
Option to add K1 connecting rods
ARP 209-5401 - ARP Main Stud Kits - Overview - SummitRacing.com - Main Studs
ARP 251-4701 - ARP Pro Series Cylinder Head Stud Kits - Overview - SummitRacing.com Head Studs
I'll maybe look into some JWT Valve Springs and if cams pop up, then maybe I'll toss those in.
Budget is 5k including the S/C kit. I'm not trying to break any records, nor do I have a HP goal in mind, I don't even have a reliable dyno in my province :47:
Thanks for any help everyone
Edit: Or, just go with the Treadstone kit. Yeah!
Complete Gasket Set
(89 Bore) and
(8.5:1 compression)
Plasma Moly Rings
Thrust Washers
