1 - 11 of 11 Posts
· The Watcher
Getting ready to install the trans and will figure out when to do the engine, here is an image over view.
Drinkware Fluid Tin Cylinder Gas
Gas Wood Circle Audio equipment Gramophone record
Wood Gas Circle Composite material Metal
Two pins are about the same size, I believe one is just a hair shorter but as seen the retaining lip is at different heights. Now unfortunate for me, I took the zip tie off to inspect everything and afterwards sat it down and it sat until it was moved/dropped/relocated by someone and the pins feel out so I have to figure out which side they go in.
Cylinder Household hardware Gas Liquid Kosher salt
What it looks like in the lower mount/carriage. Obviously its not centered while sitting on the tabs and I don't remember if the stock stuff sat the same way in the same scenario.
Gas Machine Cylinder Automotive tire Camera lens
Automotive tire Motor vehicle Rim Gas Automotive wheel system
Just displaying circlip and how much is protruding when simulating with the lip flush.
Coil Gas Auto part Motor vehicle Magenta
Hand Automotive tire Camera accessory Gas Cylinder
From the last image I should be able to figure out which side the pins go in but I have no idea what side the lip goes on and I don't think it matters but I'm projecting to install it with the lip pointing towards the front.
More to come...
· Registered
Just installed my trans side on Saturday. Gotta take timing cover off to drop in billet timing gear and ati pulley so I’ll do it all in 1 shot. Huge difference between the oem and this 1
picked up the V1R shifter bushing set as well. Replace that 2j stuff lol
· The Watcher
I had the b13 prothane bushings in with some delrin pucks for some time, it held but there was some sag when I went to pull it off and the front was being pushed in. Not bad but had some draw backs.
· The Watcher
Discussion Starter · #4 ·
Continuing on...
Tight fit and decided to press it in.
Kitchen appliance Gas Small appliance Machine Cylinder
Had a little oopsie when I had to readjust to finish pushing it through.
Gas Automotive wheel system Wood Auto part Circle
Here we have the amount of protrusion without and and with the circlip.
Drinkware Fluid Automotive lighting Gadget Automotive tire
Automotive lighting Hood Motor vehicle Automotive tire Bumper
All else is self explanatory.
Tire Automotive tire Motor vehicle Vehicle brake Bicycle part
Automotive tire Bumper Motor vehicle Rim Automotive exterior
Automotive tire Motor vehicle Automotive design Automotive exterior Rim
Automotive tire Automotive design Bumper Gas Rim
Will start on the pass. side either today or tomorrow....
· The Watcher
Decided to start on the pass. side, image over view...
The center sleeve is really tight when seated and has no play when removing, the washer on the back side of the mount sat in there with no support and had to be tapped out from its location.
Cylinder Gas Auto part Machine Magenta
Wood Gas Machine tool Cylinder Machine
Gramophone record Gas Circle Automotive wheel system Composite material
Gas Auto part Automotive wheel system Circle Machine
Wood Gas Audio equipment Metal Circle
And time for a BBQ...
Automotive tire Asphalt Road surface Automotive lighting Gas
All separated.
Grey Automotive tire Gas Art Road surface
Past the point of no return. I am unable to push the pin out of the piece that mounts to the engine and have to saw though two thick pieces of metal of the mount...wish I had a band saw or saw-zaw for that and I might have to drill the pin out or find a stronger press.
· The Watcher
Discussion Starter · #6 ·
Cut into the metal sleeves to the point of not touching the mount itself and beat the shit out of it....F'N PITA...
Gesture Automotive tire Finger Road surface Glove
Pressed it in as I couldn't find my mallet, finished product while trying to show clearance for the circlip.
Wheel Automotive tire Rim Gas Cylinder
Liquid Drinkware Fluid Food storage containers Cookware and bakeware
Hood Automotive lighting Automotive design Vehicle Automotive exterior
Inserting the pin takes more effort, I'm assuming due to a slight compression of the material, deformation of the mount during manufacturing or I messed up.
Automotive tire Musical instrument Alloy wheel Rim Gas
· The Watcher
Discussion Starter · #8 ·
I'll start by saying that my press is weak (Harbor Freight) and the pin can be pressed out and in the end I basically used a pin and a sledge hammer.
The engine side of the pin has tight tolerance to the engine side mount so had to press it in...of course.
Bicycle Bicycle part Red Material property Sports equipment
Put back together and "mount" as "normal", with a "little" extra effort. Now sitting all pretty and still.
Automotive tire Motor vehicle Rim Auto part Machine
Vehicle Automotive exterior Motor vehicle Auto part Gas
I will say that I don't think the full through bolt/nut combo is absolutely necessary due to the amount force keeping the pin on the engine side mount, but I understand the intent and feel tapping the chassis side of the pin for an adequate bolt would suffice.
About to pull it out of the garage but did start it and it feels solid but I wish I didn't re-install my Rev Auto tq dampener before hand to isolate the mounts performance, at the same time I probably don't need it anymore since I have these mounts and the V1R plate as well.
· The Watcher
Discussion Starter · #9 ·
Just pulled it out and the vibes are different, will drive it later when I need to but some noises that I have been dealing with are now gone, assuming due to the angle of how the motor was sitting with the b13 Prothane bushings for the trans and the original pass mount and the abuse it has taken.
New vibes unlocked....
· The Watcher
Discussion Starter · #11 ·
New noises from the added vibs as expected. I haven't really ripped it up to 8k yet but obviously solid. I feel as though they are "breaking in" as certain rpms are not as NVH from initial install.
The b13 trans bushing mod is really not recommended for long term and it is really hard to pin point if the tired out pass side bushing was done but some of the shifting seems easier and I think there was some added wear on the cv boots due to misalignment during operation. Previously my oil level was fine but afterwards it was reading low which means I have been running with inadequate levels of oil.
1 - 11 of 11 Posts
