1 - 4 of 4 Posts
I am Looking to get new rims and tires for my 05 1.8s. The stock rims are 15 with P195/60R15 tires currently. I am lowering about 1.5 inches sometime within the next week. What size rim/tire would fit best without rubbing? (This would be for daily driving and not drag or racing)
You can go up to 8 wide pending the offset with out rubbing, but that also depends on the tire as well. How big are you going, 17?
I didn’t have a set plan on what size I would go to but I think I would either stay with 15 or 16 inch rims like 6.5 or 7 inches wide with lower aspect ratio tires. I was mainly looking to see what people would recommend
Due to the bolt pattern it is more of a good luck on finding what you like in the size that will fit the bolt pattern. In the widths you are choosing you will have no issues with running. The Spec V came with a 17x7 stock with a 47mm offset, and the other models had 45mm offset.
1 - 4 of 4 Posts
