1 - 2 of 2 Posts
Hello,
My ex's old 2002 SE-R Spec-V has been in my yard for a bit and I need to get it going. It turns over fine, and starts normally and the instantly stalls within 1-2 seconds. Giving it gas bogs it down and stalls even faster. RPMs drop, a quick studder then off.
I did already try disconnecting the MAF sensor and it did the same thing. The fuel pump turns on and you can hear it prime fine.
What should I look into next?
Throttle body and its harness, after that checks good visual pull the codes if any.
1 - 2 of 2 Posts
