1 - 10 of 10 Posts
Top bushings came out fine, but couldn’t get the bottom to budge. I guess the metal sleeve on the bottom is seized, the rubber ended up tearing / breaking away... any suggestions ? I’ve gotten strong grips and pliers on it but I don’t want to bend or break anything, the bit of muscle I could put into it didn’t do a thing. Have tried liquid wrench and grease
Dam maybe a small torch. A pb blaster or good penetrant should work. Use channel locks.
Worse case, it's 4 bolts on top and a stop bolt on the side to pull the assembly out.
What became of this, did you try a heat gun? Pliers, some form of lube?
Sadly this happens on the shift mechanism of a old 2005 I was / am working on but it was the shift mechanism and not the interior rings on the shift cables.
I had a shift mechanism from a 2002 model sheeeyyyaaaaad I removed the one with the bushings still seized pump to it and swapped it out. Slapped my 2J-Racing Trucite on there with a cute RED anodized 2J-Racing STS and o was out the door!
What is your update please or take it to a machine shop ...?
Discussion Starter #8 (Edited by Moderator)
We were able to wedge flat heads and chisels in behind it, but we’re unsuccessful of getting it to twist off
There was a pin I was able to remove for the lower bushing assembly to come out of the car completely, then we used a torch And it came right off, after an hour or two Under the hood I wish I would have figured out how to remove it sooner haha. It seemed like brass so I’m surprised it was so resilient
Ooooooohh I was thinking at the shifter inside the car. Dam if I remember right, I had the same issue on that one at the trans. Took me 15-20 mins to get off.
Glad to read of the conquests and wins the fights and endurance with these old motorcars...
Salutes to you all and continue the fight never let up!
1 - 10 of 10 Posts
