Hey guys im having a problem with my 04 spec. it started not starting on the first try so i replaced the cam and crank sensor . it started shutting off while accelerating so i replaced them again .the problem is still going on but my starting issue is gone . the other day it shut off and when i started it back up it had a swollen a new coil pack on cyl #4. im not sure it was related but want to give as much information as i can . the facebook groups are no help i just been told to check my grounds ive check the lot of them . im at a loss with this thing any help would be great . btw the car has a fuel pump and headgasket that has been replaced in the past 3 years . ive been told to check that also
