1 - 20 of 83 Posts
so i was driving from Seattle Washington to eastern Washington. about 120 miles into the trip, my power steering goes out, and my oil temp goes extremely high. so i throw it in neutral and coast about 2 miles to the rest stop. turns out my serpentine belt broke and popped a hole in my radiator/radiator hose. i get it towed to Kennewick and have towed again to a mechanic. turns out that i spun a rod bearing. he said from running to high of rpm for too long. or a lack of oil. but i just changed the oil in the begining of June with full synthetic. now im in need of a new motor. he said he could get the qr25 for 2500. the qr20 for 1300. and the 1.8 for about 600. now i just need to figure out what i need to do. because money is an issue. quit my job because i moved back to the seattle for the summer. so whats the best route to go? or does anybody want to buy my car with the bad motor? in washington.
I just spun a rod bearing last month . Ur best option is call junkyards they go used
For about $1500 . The swap is rely easy . I am rebuilding my motor but the other
Options were junk motor and have it running in 2 days do a quick swap, or take the
Oil pan out and head and replace the bad bearings .
how hard is it to replace the bearing? its possibly drivable but i should probably tow it. and my AAA only allows for 100 miles.
time for a credit card for you to get your car rebuilt.
ive been applying for credit cards for a few months now. no luck. i need to fix my car though. or sell it as a project and buy something new.
Its not that hard . Just a lot of time . Like I said cheapest option
Is a junk motor take old one out put new one in have it running in
One or two days
Where in WA are you located?
That is some ways away from where I am.
But as other said, try to get a good and fairly decent price QR and drop it in there. Another route is to try and repair the bad parts on the engine your currently have.
Discussion Starter #12
i see your in bothell. what did you have in mind? your only about 40 minutes from my place in north bend
id say buy a rebuild and have your pup running...i fixed the bearing on my car a while back and my motor still poped afterwards 2 months later...its alot of work to replace a bearing >>>>>imo<<<<<<get a used engine and drop it in it will run the same i couldnt tell the diffrence on mine...
ps.....i drive my car like an ahole so that might be a reason why it blew on me... maybe i didnt break it in right or something but good luck and keep your sentra...
Id make sure your not getting dicked first....
The mechanics reasoning for a spun bearing doesn't really fit with the incident. Sounds like a load of bullshit to me.
plus if you were taking a trip you werent in high rpms to begin with...plus u just changed the oil so i dought it was low on oil...i say get it checked by someone else ...this could be a easy belt fix and be on your way
Reactions: Jager
Discussion Starter #18
I def don't wanna get screwed on this. There's a Nissan guy in town that I'm gonna have look at it too. I can hear it rattlin when I start the car. It still runs and drives. Just not good at all. Do you think I should put the belt in and see if that helps the problem? Or swap and sr20ve in it? It's just gonna take some time once I'm not working right now.
Do you know why it spun a bearing? That just doesn't randomly happen, oil delivery problem?, did you have fuel dilution?, low oil?, detonation?, lagging the engine too much can cause it too
1 - 20 of 83 Posts
