1 - 4 of 4 Posts
Hi yall, I wanted to know if someone knew how closely related the 350z clutch pedal assembly is to the spec's?
Does the spec have 3 bolts too? (1 on top 2 in front) with 2 senors (top and bottom) and a colter pin holding the master?
I ask because RJM Preformance makes some 350z and 370z fully adjustable clutch pedal assembles for the cars and Id be interested to find out if it fits up
https://www.google.com/url?sa=t&sou...MQFnoECA4QAQ&usg=AOvVaw0KGGwgYIwPSDRxPwNEuzIg
https://www.google.com/url?sa=t&sou...MQFnoECBAQAQ&usg=AOvVaw2E4CWXWiOVRi2We1CfNM0Z
So the firewall bolts spacing for the master cylinder are the same, assuming sensor/switches are the same they can be located any where and is not a concern.
I would need to look at the 3rd bolt location but keep in mind rod length from the pedal/clevis to the master is different but not by much. I will look into it as well.
The upper mount is highly adjustable and easily removable, worse case make a replacement bracket to fit the needs.
1 - 4 of 4 Posts
