1 - 20 of 22 Posts
By: sickwithit
Wheel, Lug, and bolts
Bolt pattern: 4X114.3
Lugnuts: 12x1.25
Wheel Studs: 42mm front and 39mm rear.
Spec V 02-03
Weight: ~24 lbs
Wheel offset: 47mm
Spec V 04+
Weight: ?
Wheel offset: 47mm
Spring Rates
Stock Spring Rate Assumptions
123F/190R 2000-2003 GXE
123F/190R 2000-2003 XE
134F/190R 2000-2001 SE w/ 15” rims
134F/212R 2000-2001 SE w/ 16” rims
134F/212R 2002-2003 Se-r
134F/190R 2003 LE
154F/247R 2002+ Spec V
Aftermarket Spring Rate Assumptions
190F/240R Progress
150F/190R Sprint
170F/270R Tein S Tech
150F/250R Tein H Tech
180F/300R Nismo S-tune
???F/???R SpecV Sportline 4.6263 F1.8 R1.6
180F/300R SpecV Prokits 6362.140 F1.2 R1.0
142F/179R Non-SpecV Sportline 4.5563 F1.5 R1.4
???F/???R Non-SpecV Prokits 6355.140 F1.2 R1.0
168F/258R Tanabe NF210: F/R: 1.3"/1.1" - "Normal Feeling"
207F/314R Tanabe GF210: F/R: 1.3"/1.1" - "Grip Feeling"
174F/258R Tanabe DF210: F/R: 1.8"/1.8" - "Dress-Up Form"
Coilovers
390F/280R JIC FLT-A2
336F/336R Tein Basics
336F/280R Tein SS
Fender Rolling
You will likely need to roll your rear fenders if you are going to run a 225 tire with a 40 offset rim on a lowered car. Front clearance should be ok.
Sway Bar Info
Eibach Sway Bars
-Front and Rear
-25mm Front 19mm Rear
NISMO R-tune Thicker Rear Sway Bar
-Adjustable 25mm diameter sway bar, solid steel
-Includes firmer bushings with higher density rubber
OEM Spec V Sway Bars
-Front and Rear
-22mm front / 38mm rear
-Diameters measured with digital Calipers
-non adjustable
- The rear sway bar is contained in rear axle housing. The purpouse is to reduce body roll in cornering. The aftermarket Bolt on rear sway bar will just add in reducing said Body roll.
Stillen Sway Bars
-Front and Rear
-24mm front / 25mm rear
-rear is adjustable
Progress Rear Sway Bar
-19mm
Spec V OEM and Nismo Front Sway bar Rates
DIAMETER RATE
.866 (Stock)---------------271.7 LB
.906 (Nismo)---------------325.4 LB
General Suspension Terminology
A-arm: a wishbone shaped suspension member, usually with a pivot axis intersecting the end of each leg and multiple-axis pivot such as a ball joint at its apex
Acceleration: change in velocity of an object over time, either linear or rotational
Anti-squat: (anti-lift on front axle) rear suspension geometry that resists compression under acceleration; anti-squat increases traction on rwd cars, anti-lift decreases traction on fwd cars
Anti-dive: suspension geometry that resists pitch movements under braking, values about 50% are seldom used
Anti-roll bar: a torsion spring that resists independent motion of the wheels on opposite sides of the car, increases weight transfer at the end of the car at which it is mounted
Axle wrap, windup: often oscillatory rotation of a solid axle about its axis due to driving or braking torque, usually when located by a leaf spring
Balanced: in cornering, a condition in which the front and rear tires operate with equal slip angles
Body roll: tendency of a car to lean toward the outside of a turn
Bump steer: a steering geometry error in which the front wheels are turned on the steering axis by suspension movement
Bumpstop: elastic cushion that softens the impact when suspension travel reaches its limit
Bushing, suspension: rubber or plastic bearing in suspension joint that reduces transmission of vibration and road noise to chassis
Bushing compliance: deflection of suspension bushing resulting in inaccurate suspension geometry
Camber: inclination of a wheel outward with respect to the body
Camber correction, camber curve: change in camber angle of the wheel as a function of suspension travel or body roll
Caster: inclination of the steering axis in longitudinal plane
Center of gravity: center of mass
Center of mass: the point in a body or system of bodies at which the whole mass may be considered as concentrated
Coil bind: occurs when a coil spring is compressed fully so that each loop of wire is in contact with the loop on either side
Contact patch: the interface between the tire and the pavement
Control arm: a swinging suspension member to which the axle stub, or hub carrier in the case of a driven wheel, is rigidly attached
Characteristic frequency: the frequency at which a suspension will oscillate if left undamped, a function of wheel rate and sprung mass
Coefficient of friction: rate of increase of maximum friction force relative to a given increase in contact force; slope of traction/load curve
Critically damped: damping of a spring-mass system is at the minimum level that will prevent the system from overshooting its final position
Damper: a mechanism to control unwanted movement by converting mechanical energy to heat
Double wishbone (also double a-arm): a suspension configuration in which an upper and a lower a-arm control an upright hub carrier
Equilibrium: a condition in which all forces are balanced and no acceleration occurs, note that this is not necessarily static
Foamy bumpstop (also elastomer, long-travel bumpstop, supplemental spring): a bumpstop mode of a foamed polymer that compresses significantly before preventing further suspension travel, and can enter into normal movement of the suspension
Friction: a force that resists relative motion between two bodies in contact
Handling: a vehicles combination of traction, responsiveness, cornering balance and ride quality
Ideally damped: a sprung mass system is slightly undamped, so the system approaches its final static position quickly while maintaining acceptable limits for overshoot and oscillation
Independent suspension: suspension in which a disturbance of one wheel does not directly effect the transversely opposite wheel
Inertia: a property of matter by which it remain in rest or in uniform motion along a straight line or about fixed rotational axis unless acted upon by some external force
Initial understeer: reluctance of vehicle to begin rotating about its vertical axis on entrance to a turn
Kinetic energy: energy in an object due to speed
Lateral acceleration: rate of change in direction or a vehicles velocity vector on a horizontal plane
Leaf spring: a long, flat spring that acts in bending, usually used in groups
Linearity: mathematical concept; output of a system is proportional to an input, as with a constant-rate spring
Lowering: reducing the static height of a vehicle sprung mass
Lowering spring: a spring designed to accomplish lowering
MacPhearson strut: a telescopic member incorporating damping with the wheel rigidly attached at its lower end, such that the strut maintains the wheel in the camber direction; the upper end is fixed to the body and the lower end is located by linkages which pick up the lateral and longitudinal forces
Mass: the property of a body that is a measure of its inertia, that is commonly taken as a measure of the amount of material it contains
Model: a system of data and inferences, a physical representation, or a description or analogy used to help visualize or describe and entity
Motion ratio: the ratio between vertical motion of the wheel and compression of the spring, also between wheel rate and spring rate
Multi-link: similar to a double wishbone suspension, multiple linkages react to lateral and longitudinal forces
Newton’s second law of motion: the sum of the forces acting on a body is equal to the body’s mass (inertia) times its acceleration
Offset: distance between the plane where the wheel contacts the hub and the plane that defines the centerline of the wheel
Overdamped: damping of a spring-mass system is high, so that no oscillation occur in response to an input and the system does not overshoot its final static position; system is typically slow to respond to inputs
Oversteer: in cornering, a condition in which the rear tires operate at a high slip angle than the front tires
Panhard bar: method of lateral location of a solid axle in which a transverse member is attached to the axle at one end and to the chassis at the other end; roll center is defined by the point at which that panhard bar crosses the vehicle center line and can move vertically with respect to both the axle and the chassis
Passive steering: change is steer angle of rear wheels dude to suspension bushing deflection
Performance: a vehicles ability to meet operational requirements; with anything other than a race car, this involves much more than going fast
Performance spring: a spring designed to achieve optimum compliance with operational requirements; especially handling
Plow: severe understeer
Pilot load: a force transmitted through a single point; loosely, force transmitted through a single joint or pivot, as of a suspension
Polyurethane: a synthetic polymer that can be formulated for a wide range or hardness; recovers completely from high loads; remains flexible and shock resistant down to 0*F and increases in stiffness gradually at lower temperatures; highly resistant to abrasion and environmental degradation
Position-sensitive device: a device in which force between ends depends on position relative to each other, e.g. a spring
Potential energy: energy in an object due to position
Progressive spring: a spring having a rate that increase with increasing positive deflection
Race car: a vehicle meant to be optimized for maximum speed with adequate durability under race conditions
Recovery: behavior and required for a vehicle to return to its previous state after experiencing a disturbance
Recovery rate (of elastomer components): time required for a deformed elastomer to regain force/deflection characteristics it had prior to being deformed
Roll axis: a line intersecting the front and rear roll centers
Roll center: the point in the transverse vertical plane through any pair of wheel centers at which lateral forces may be applied to the sprung mass without producing suspension roll
Roll moment: torque about the roll axis caused by lateral acceleration, tending to roll the car body to the outside of a turn
Roll stiffness: restoring torque exerted by a vehicles suspension in resistance to body roll
Roll steer: change in steering angle in front and rear wheels due to suspension roll
Rolling resistance: negative longitudinal force resulting from energy losses due to deformation of a rolling tire
Rotational velocity: rational speed about a particular axis
Semi-trailing arm: control arm configuration in which the pivot axis is angled relative to the vehicles centerline
Shock absorber: a damper that operates in tension and compression but does not resist bending loads
Skid pad: a flat, circular area of pavement used to determine cornering characteristics of a vehicle
Slip angle: difference between orientation of the wheel plane and direction of wheel travel
Snap oversteer: oversteer that begins suddenly, especially if at a rate faster than the driver can correct; judgment depends on driver skill and experience
Solid axle: an axle configuration in which the wheel planes cannot move independently of one another
Speed-sensitive device: a device in which force between ends depends on their speed relative to each other, e.g. a damper
Spherical bearing: a low-speed baring in which load can be transmitted at a variable angle relative to the axis of rotation
Spring eye: the looped end of a leaf spring, used as a mounting pivot
Spring rate: the ratio of applied force to deflection of a spring, can be constant or variable
Center of sprung mass: center of mass of a vehicles sprung mass
Steering axis: the line defined by the pivot points of the steering suspension components; in most cased either ball-joint to ball-joint or ball-joint to upper strut bearing
Straight spring; a spring having a constant rate
Street car: a vehicle in which ultimate performance is compromised to achieve comfort, reliability, durability, low cost and low maintenance
Subframe: a frame that drivetrain and/or suspension parts are mounted to, which in turn is mounted to the vehicles body
Supplemental springs: long-travel, elastomer bumpstops that participate in normal suspension movement of the vehicle
Swing axle: form of independent suspension in which the wheel is rigidly mounted to a control arm which has a pivot axis parallel to the longitudinal axis of the vehicle
Swing axis jacking (also jacking): tendency of wheels to move vertically in response to lateral force, caused by an excessively high roll center in any suspension configuration
Tender spring: spring used to hold primary spring in position during full suspension droop; is completely compressed (in coil bind) during normal suspension movement
Terminal oversteer: tendency of vehicle to continue rotating about its vertical axis when exiting a turn
Toe: the difference in the transverse distances between the wheel planes of a pair of wheels, taken at the extreme rear and front points of the tire treads; when the distance at the rear is greater, the wheels are “toed-in” by this amount, and where smaller, the wheels are “toed-out”
Torque: twisting force, thought of a linear force acting on a lever arm
Torsion bar spring: a spring that is straight in shape and acts by resisting torque rather than linear forces
Track width: a lateral distance between the center of tire contact of a pair of wheels
Traction bar: used to control rotation of a live axle mounted on leaf springs; a rigid member with a snubber on the end bolts to the axle mount; snubber meets the forward spring eye under driving torque and prevents rotation but otherwise does not interfere with the action of the spring
Traction/load curve: their relationship between vertical load applied to a tire and the maximum friction force that can be generated
Transient: response of a vehicle to changing road surface or input
Turn-in: initial response of a vehicle when changing from a straight to a turning path of travel
Underdamped: damping of a spring-mass system is low, so that oscillations occur in response to an input and the system overshoots its final static position
Undesteer: in cornering, a condition in which the front tire operate at a higher slip angle than the rear tires
Unsprung mass: mass acted upon directly by the road surface, i.e., the wheel, tire, hub, spindle, brakes, and a portion of the suspension including the control arms, spring and damper
Valving: internal passages of a damping unit (i.e., strut carriage or shock absorber) responsible for its damping characteristics
Velocity: a quantity having both direction and speed
Watts linkage: method of lateral location of a solid axle in which a vertical member is mounted to the axle via a pivot, and each of its ends is connected to the chassis by a transverse pushrod; roll center is defined by the axle pivot and does not move laterally or vertically with respect to the axle
Weight: the effect that gravity has on mass, proportional to the strength of the gravitational field and the quantity of mass
Weight transfer: method by which a restoring torque (resistance to rotation) is generated when a vehicle is accelerated by application of force on a plane not containing its center of mass, i.e., the road surface
Weight transfer distribution: relative amount of lateral weight transfer at the front and rear of a vehicle when cornering
Wheel hop: periodic vertical oscillation of a wheel resulting in loss of traction
Wheel rate: the stiffness of a suspension as it acts at the contact patch, accounting for the effects of suspension geometry on the leverage of the spring
Work: expenditure of energy by applying a moving force over a distance: W=FxD
Me i got a question ... im looking at a set of springs that will lower the car 2 inch in front and rear so im wondering if the wheels still gonna clear the fenders without touching ( I got 215 ) and if they will touch if im getting 225 on 17 inch rims
thank you
wow did alot of reading and learned a couple things :2:
Me i got a question ... im looking at a set of springs that will lower the car 2 inch in front and rear so im wondering if the wheels still gonna clear the fenders without touching ( I got 215 )prob not without rolling in the rear and if they will touch if im getting 225 on 17 inch rims definitely will rub
thank you
Anybody have experience with Eibach Ground Control Sleeves? I'm already invested into my Koni Yellows so Coilovers are out of the question. Another inch drop would be perfect. Currently on Pro Kits
Are the spring rates universal or are they custom to each order? I heard Koni's bottom out with them?
They can as the Koni inserts/struts are built just like any other shock/strut. The reason why coilovers don't bottom out is that you're actually lowering the whole shock body/spring assembly into the knuckle mount rather than just the springs pushing into the shock itself. Just imagine being on regular lowering springs but this time you can lower them even more. You can get any spring rate at the time of order IIRC. Just give them a call. I'm sure they can help you out.
Thanks Buddy. I just want to drop a little more in the front so I don't think I'll have issues bottoming out, I just want the option of being able to go higher if needed (I hate scraping and going extra slow).
the ground controls and koni's go well
just don't exceed the spring rate the konis are built for
about 8kg iirc was all they would take
with the valving adjustment available
6-7kg is good for street and the koni's will easily absorb those rates
racers tried to run 10-12kg springs here and that destroyed the koni's quickly
ask the ground control people what spring rate to use with the koni's, for your purpose.
they were very helpful to me,
years ago.
the above has changed
but 1st look whats back
swaybars and prosports
http://www.2j-racing.com/this-just-...t-for-02-06-nissan-sentra-ser-spec-4-cyl.html
and forget the koni inserts
use these instead
full struts
and can be custom set up when ordered for any spring you want
http://www.2j-racing.com/this-just-...00-06-nissan-sentra-b15-ser-spec-v-front.html
even tein has redesigned and repriced their basics
http://www.2j-racing.com/this-just-...-06-nissan-sentra-street-basis-coilovers.html
and us steel has released fwd offset wheels
as big as 16x10 and 17x9
http://www.uswheel.com/collections/fwd-drift-series
a set of basics and some wide wheels and sticky tires
and you have an inexpensive, good handling, lowerd car
use these instead
full struts
@yogi b I must ask......would you not still recommend BC over Tein Basics? They seem worth the minimal extra cost to me. Maybe I am wrong about that.
And I could kinda dig on some of this US steel wheels. Old school ;)
use these instead
full struts
Hi Barry, are these Koni's confirmed bolt on replacements? The picture looks like a stock photo. Same goes with the Teins. Just wondering.
the BC'S offer more custom combinations and adjustments
and also other versions
for example, i use the BC inverted struts
[they offer a wide range of spring choices and they can change height, dampening and preload, independently]
the basics are just that, basic
[just preload is adjustable{changes height}, no custom springs, without extra cost]
can't get thru to joe
thank you for bringing that up
as i could not find them on the koni site, after seeing your post
my apologies i may have jumped too soon
and now looking at joe's price, i think they may be inserts
- - - Updated - - -
the teins were the 1st thing i checked
they are for real
What BC spring rates would be recommend for a boosted 08 SpecV?
I recommend you ask Joe and buy what he says. Tell him how the car will be used and where and what kind of surfaces.
I use the recommended (for b15) street use 7k. I run back roads (hard) in TN and I like them a lot. Considering you will have a power increase I'd say go 8k or more, but don't over do it. If you are not racing the car it may not be worth the difference in ride quality. Your car will handle Fantastic with 8k springs. Especially with sway bars. If sway bars are not an option for you......"maybe" 9k.
But Ask Joe.....Joe Knows. Give him as much info as possible.
I might run 7k/8k or 8k/9k f/r with sway bars. It really depends on how the car will be used. 2002blackspec_v runs a 7/8 (maybe it was 8/7) combo and he is going stiffer. He is boosted (b15) and he autocrosses his car.
For drags you want stiff rear springs to fight lift. But on the street under hard braking the rear of the car would get excessive lift from the stiffer rear and softer front springs. Most people run the same rate front and back. But not everyone. Like I said ask Joes. The use and entire suspension setup matters.
You can fight body roll side to side with springs if sway bars aren't an option. But that effects ride. And there are other considerations. Keep dive and lift in mind.
Yeah its more complicated than it seems.
You'd think you could run whatever and tune it with the dampers, but that is only true to a certain extent. The springs kinda do what they're gonna do , the dampers just slow down the springs, but they DO work together. That's in super simple terms. Anyway...you can't "stop" lift with dampers. You can slow it down and in essence lessen it. You can however stop lift with the springs on the opposite end of the car. But at this point things like the weight of the car f/r come into play. (L/R too for that matter)
I guess I could also kinda explain in this way.....the springs are a certain stiffness. No matter how your dampers are set (valved), the springs will NEVER be softer. However you can "kinda" stiffen them up with dampers. This isn't really how dampers are used though. It all has to work together according to the weight of the car and the road surface. A rally car, track car, and drag car all required different spring rates even though the weight of the cars may be the same. You hit a bump and the spring wants to bounce your car (and/or your wheels) around. The job of the damper is to tame the bound and rebound of the spring so that your wheels maintain contact with the road.
If you can afford it get the BCs Barry has (inverted). Ideally you want to be able to adjust bound AND rebound so if you have a big budget get Remote Reservoir which have bound & rebound damper settings.
Most people run the same rate so its balanced. It would be balanced with perfectly balanced weight f/r. That's what corner scales are for.
Reactions: yogi b
1 - 20 of 22 Posts
