21 - 22 of 22 Posts
joe set mine up
it's perfect
just order and ask him to set them up for you
if you ask before order, prob no return answer, he gets a 100 of those a day
as it's said money talks
my car has had from 156hp to 316hp
two different engines [but close to the same weight]
and on a non competitive level, has rallied [mild poker runs and still bent a wheel], run the mountains and been a real drag car
all with 8 kg springs rear and 7 kg springs front
this gives a comfy ride [for a trackable car]
lean is controlled by nismo sway bars front and rear with poly end-links
and the roll centers have been changed with a panhard bar in the rear and the RSK up front
car is also lowerd 2.25" and uses the bumpsteer kit
if your into curves more than straight-a-ways
keep the springs balanced
most street only users are in the 6kg-7kg range
the occasional racers at 8-9kg and hard core at 10kg
track time 10kg and above
control the lean with sway bars and poly bushings
use the lowest spring rates that prevent harsh bottoming on the roads you use
imo
ah
how do you do that
with coils it's easy to set everthing, including weight distribution
even side to side
this can be further assisted by wheel choice
drag set up [70% weight up front on scales static]
forward rake
DD Level 55/45
supreme mtn runner 50/50
[will spin quickly]
only runs in the dark lol
rally work 4x4 look
coilovers are very adaptive
i love them
they make the impossible, easy
21 - 22 of 22 Posts
