So i spun a bearing and I took out the crank and sent it to the machine shop. getting it back soon. I was wondering what the torque specs were for the main and rod bearings. Also when applying the bolts for the bottom end what are the torque specs for the bottom end as well. Im a bit of a novice and im learning as i go. so if there is any other advice im open to it. Thanks all!! 2002 spec v
