Hello all, this is my first post and also my first project build. Nothing fancy here at all, forced to do a rebuild of my QR25DE due to a precat failure and wanted to get some tips and feedback on things I should and should not do. Looking to go all stock but would like any suggestions or links to any worthwhile upgrades. I was looking to remove my balance shaft as this is an 05 altima, but didn't know if most guys just pull the whole thing or just remove the chain. Also I pulled the head and pulled out all the valves. Was burning oil for quite a while and had a lot of oil and carbon buildup on all the valves. looking to send the head out to be cleaned up and possibly decked, and then lapping the valves myself. I did not blow the headgasket but I think my rings are shot. I originally did a wet dry compression test and pulled a 190psi wet and a 65psi dry on all cylinders
Motor already pulled but bottom end hasn't been unassembled yet, had to purchase a special Torx bit called a Torx Plus to get the flywheel off
