1 - 11 of 11 Posts
Does anyone know how much the single flywheel weighs in the basic conversion kit from summit?
Drive to El Cajon and do a will call to JWT.
I am really close to JWT, but... I don't have that kind of money. I get the wholesale price at summit, so I was considering that kit. I am getting noise from the flywheel. That's why I'm going to eventually change it.
Its probly the throw out bearing but still involves a clutch replacement. I would call and ask to see that it is or isnt a dual mass
Discussion Starter · #8 ·
Noise goes away when I push the crutch pedal. And the site says it's a single mass conversion.
If you can get it under 250, you're set, but if not, look at rockauto. They list that same one under a different brand but exactly the same part number.
173380
Discussion Starter · #10 ·
I got the new kit in and the flywheel was 24lbs. I also changed my tranny fluid with MOTUL. Shifting is now effortless and reverse grinding is gone. Btw, worst clutch job ever!
Do a twin disc....then you can complain...
1 - 11 of 11 Posts
