1 - 20 of 22 Posts
I've been looking at lips for awhile now hoping to find something other than the mach or sti lips. I found this jewel ripped off on the road like destiny. On the back it has ribs for strength vertically & reads Chevy Cav 1. & a serial #.. With much cutting, grinding, warping, & sanding; this is the test fit result. You can see clear packing tape, that wont stay. I've since sanded this lip & painted gloss black to match the tux paint job. Will put on tonight & have final picks tomorrow, if it will stop raining here. :evil:
Car looks good with that lip man
Reactions: Sr. Spec
Not bad.
Are you going to do a write up?
An oem chevy caviler front lip...do the math guys.
Discussion Starter #16
Yes, its 3" in height. If thats what your reffering to as width. If you actually mean width, than no. It comes up about a half inch off the wheel well, wich the mach must be cut. I trimmed my corners to mach the angle of the wheel well
Your math = an assumption, which has no value. Its off the cadilac cts. I finally hunted it down.
More like what I observed was incorrect, I saw cav and assumed something else other than what you found out what it actually was, Chevy product none the less.
Discussion Starter #18
What you observed was correct, what you assumed was incorrect. Just like your math. Lol
I still think it looks great, but I decided to go another direction... one that many others have already done...
I think you should try raising up the sides a little. You'll have to trim around the fog light holes a little but I think it will make the center of it look better!
Just my 2 cents...
1 - 20 of 22 Posts
