2006 SER Spec V 6 speed manual. Start up crank takes a little longer than usual but always starts, is that normal? Throttle pedal has a 1/2 inch dead space before it throttles up. when it does throttle up, it jumps up to 2000 rpm, and back down to 1000/1100 once I let off the pedal. When driving, and in gear, if I let off the gas it obviously slows down but when I push the pedal again is jerks. It's like the throttle is either idle or straight to 2000; no in-between. RPMs don't stop at 2000 if I keep throttling up tho. It's really bad at lower speeds and rpms, but the lag still happens at any speed. I hope that makes sence. Please HELP if you can. it doesn't feel good driving, and I assume it's not good for the car either.....
